JeepFreak21
- Cameron Park, CA
How much of the inside of the side gears should you see with the axle shaft in place? Any? Should you see any splines on the axle shaft? Should the end of the shaft be flush with the inside edge of the side gear?
And on the other end... how much space should there be between the end of the axle tube and the beginning of the axle shaft "flange"? (I'm talking to the inside of the the u-joint)
LMK if I need to illustrate my questions :wierd:
Thanks,
Billy
Thanks,
Billy
