Vanimal
- escondido, ca
Has anyone used a martensitic stainless steel for cage construction?
It seems to have a lot of similar properties to chromoly, and i know Ford uses it quite a bit. It's also making it's way into higher end mountain bike frames, in place of titanium and chromoly.
I ask because i have a friend who produces heat treated martenistic stainless tubing, and is pretty knowledgable in welding it and whatnot. It should end up lighter and stronger than a DOM cage. i can get the tubing probably cheaper than anything else including probably hrew, or possibly free. these seem like pretty good reasons to give it a shot, so i figured i'd ask if anyone has attempted to use it, or has seen it used before. i'm guessing not due to cost, but worth a shot.
