DPG off-road leaf spring plates-$50
Xj drop pitman arm brand new-$25
Dana 30 knuckle-$10
Ford F-150 leveling kit missing two flange nuts. Mad by ready lift $20
Xj ax15 oem flywheel
Winch hawse-$25 all aluminum
JCR diy winch bumper already built with tie in plates-$350
What year is the flywheel?
Dana 30 knuckle-$10
What side knuckle is it?
How much drop on the pitman arm? I'm intrested.
Damn im in need of a driver. I dont wanna drill thru a goferit insert to mount my steering.
I can get you a driver side let me check the shop
Would a knuckle that is already drilled for 1 ton TREs work?
Not sure what a one ton taper starts at. Needs to be able to be drilled to 5/8"
I have a driver side for you.
Sweet. How much? Ill take it
