Dundy
- Taunton, MA
Drag link under the knuckle?
Is this at ride height?
I'd set it down at full bump and see what you have room for before you do anything.
won't be able too, as knuckles are drilled/reamed for TRE's from above. the draglink is on top of the hi-steer, if I flip it, 10lbs of shit in 5lbs bag.Drag link under the knuckle?
Keep the front stretch. Add TNT/treks inner wheel wells for clearance.
Here's my advice.
How tall are you?
Get your seats mocked up with the t-case out and situate them where you are comfortable with some amount of head room.
Put the t-case back in and clock it until there's about 1" before it hits your seat.
That's all you're going to be able to get out of it.
If you look at where my NP205 is, I could have clocked it up more. But honestly, I don't want to have my helmet/head riding the roof just for an inch of ground clearance.
I'd gladly give that up for safety. My belly pan hangs 1.5" below the frame rails. But it's completely smooth/flat.
