Dr. Dyno
- Al Ain, UAE
Dino, I've always wondered, is that imperial or US gallons?
Sorry, I keep forgetting about the two different sizes of gallons. It's imperial gallons.
OK, I am thinking about this swap too mainly for the fuel mileage increase. I am up in the air between this and stroked 4.0l. I only get somewhere around 15 mpg with my current mods on a 200K 4.0l. Will this get worse when I stroke the engine and add the 23lb injectors? Can I swap in the LS1 or an LS3 and get 20 mpg? Let me know if I am wrong here.
I just think if you're doing an LSx swap into anything your goal should be becoming a total badass
Why not be badass and get great mileage? I had a mild built LT1/T-56 With a LT4 top end in a 2wd S-10 with 4.88's and 32's The thing had power and mileage.I just think if you're doing an LSx swap into anything your goal should be becoming a total badass, not mileage.
I kind of needed cash, and had another project. And the price offered was right. It was actually a lot more than the time/money I had actually put in it. Hopefully soon I can build a MJ or 2nd gen dakota with an LS motor in it (=That sounded like a fun toy--why'd you get rid of it?
The rating system was also different in the days of the 450+ hp Chevelle. That's why you'll see ratings today listed as SAE Net vs SAE gross from back in the day.might as well go LS9 then.:firedevil
...gosh that's a lot of money though. I think a mild LS1/truck engine equivilant (get one from an Escalade, they have better heads and a hotter cam) would be good- just remember that you don't want too big a cam and stuff as you want torque to go wheeling with.
About the guy who talks about 200hp v8s, that's smogger engines. pre-smoggers usually had 280-340hp, and of course the higher performance engines were rated to 450hp back then. Oh, the days before the EPA...:thumbup:
http://en.wikipedia.org/wiki/Horsepower#SAE_gross_horsepowerSAE gross horsepower
Prior to the 1972 model year, American automakers rated and advertised their engines in brake horsepower (bhp), frequently referred to as SAE gross horsepower, because it was measured in accord with the protocols defined in SAE standards J245 and J1995. As with other brake horsepower test protocols, SAE gross hp was measured using a stock test engine, generally running with few belt-driven accessories and sometimes fitted with long tube (test headers) in lieu of the OEM exhaust manifolds. The atmospheric correction standards for barometric pressure, humidity and temperature for testing were relatively idealistic.
[edit] SAE net horsepower
In the United States, the term bhp fell into disuse in 1971-72, as automakers began to quote power in terms of SAE net horsepower in accord with SAE standard J1349. Like SAE gross and other brake horsepower protocols, SAE Net hp is measured at the engine's crankshaft, and so does not account for transmission losses. However, the SAE net hp testing protocol calls for standard production-type belt-driven accessories, air cleaner, emission controls, exhaust system, and other power-consuming accessories. This produces ratings in closer alignment with the power produced by the engine as it is actually configured and sold.
