Well pretty sure the issue is almost fixed. Me and mn-jeep member spent a few hours today going through a bunch of stuff trying to figure out what was causing my stutter.
We determined that, first of all, my damn voltmeter that i was using for the past 4 years has bad leads so it was reading about a volt and a half low. How freaking stupid is that. So my TPS harness and TCU are totally fine. But the TPS on the car was bad and was way out of adjustment. So good thing i bought a new TPS just incase.
So we popped a new tps in and got it to adjust perfectly. Took the truck for a spin and it started to shift and idle way better. But the stutter was still there. For a minute Jason thought it could be a mechanical issue with my rear end or tranny.
We get back into the garage, he checks the rear end, it its fine no play in drive shaft, no chipped teeth in the diff.
Thats when we decided to order pizza and have a beer
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Jason said we should check my plugs and wires. As soon as he got the plugs out he said that the plugs i got are not the best (Platinum Bosh). And the wires were way loose on the cap and the plugs.
Plus while the plugs were out we did a compression test and got 125 on all cylinders except the front one, that one was 115. 125 seems pretty low but at least its pretty consistent.
Ate Pizza.
Parts arrived and we got new plugs in and new wires in. Took the Jeep for a spin. What a difference, the stutter was almost gone. I could only notice a very little misfire when driving home for an hour and a half at about 70mph for about a millimeter on the gas pedal.
So my thought is that this all was caused by bad wires and plugs. Wires were shitty NAPA wires that did not fit snug enough around the plugs and distributor cap.
The remaining stutter is a miss that i am pretty sure is caused by a faulty distributor.
One little detail i forgot to mention before i even posted this thread is that previous owner had a valve cover explode on him while doing a 500 mile drive. He only noticed it when he smelled raw oil inside the car. So when i got the car and replaced the distributor cap it was full of oil. My thought is that oil might have damaged the distributor.
So i am going to get a used distributor and see if this cures the rest of the miss i got.
oh, and thanks for the heads up on the tranny fluid.
