Creighton
- Outer Banks, NC
I just had the exact same thing on my 2000 XJ w/ 94k miles. Oil pump was bad.
ayers05 said:I finally succumbed and brought the Jeep to the dealer where I bought it and luckily for me I bought a 3 year engine warranty 2 years ago. The only thing is I would always do my own oil changes and did not know to keep my receipts from the purchase of that oil to aid in the warranty process. Does anyone know if that voids my contract? I have no receipts and no record other than every 6 months I would change the oil.
Any guidance appreciated. Was 2000 just not a good year or am I a bad XJ owner?
(On the plus side I am enjoying learning about my Jeep through this site and this whole ordeal).
ayers05 said:There appears to be a crack or a welding defect in the cylinder head between the 3rd and 4th set of springs (which is the same view I had when removing the oil filler cap) but nowhere else.
jeep-noob said:where do you find the "0331" on the head?
thank you99XJSPORT06 said:Look on the drivers side of the engine (if you're standing infront of the jeep, looking towards the windshield, it will be on your right). About halfway down the engine, around the #3 and #4 cylinders, you'll see the casting number on the head. You'll probably need a flashlight to see it better.
Dr. Dyno said:Replace it with a '96-'98 era 0630 head. It has the same port dimensions as the '91-'95 7120 head so it'll outperform the 0331 head, and it's also much less crack-prone.
donovanb62 said:They said that unless I could prove that the overheating caused any of these problems (which I can't, how could I?), that I would have paid the exact same cost the first time I went in, if they could have found the problem. Unfortunately for me, they said, it's just something that is hard to figure out, but there's no way of telling which happened first and what caused what. They said more than likely that I had all these problems the first time I overheated and they were sorry for not figuring it out sooner.
Dr. Dyno said:Unfortunately for you they're probably at least partly right. The head was probably cracked from the outset and everything else followed. I'm sorry it turned out to be such an expensive repair bill but if the stealership really did pressure test the cooling system repeatedly and it was OK, they would have had no reason to suspect a cracked head. I can only conclude that the pressure test isn't foolproof.
All of the cases of cracked 0331 head castings that I've heard of have occurred only in year 2000 models. It would seem that a bad batch of castings came out that year. The 2001+ heads seem to be OK so those who own a newer model can rest easy.
Anyone with a 2000 model TJ, XJ, or WJ should watch out for the telltale early signs of a cracked head i.e. unexplained coolant loss, overheating. If you wait until you have an oil pressure drop or knocking from the engine, you may be looking at a total engine rebuild.
I think there's been enough cases to justify anyone who owns a 2000 4.0 Jeep to form a class action suit and force DC to recall these vehicles to have the heads replaced.
92DripCherokee said:I did my homework on the 2000 model year, there were no major recalls besides a heat shield. I thought I had a creampuff.
Are we looking at another defect on the scale of the infamous tubular exhaust manifold?
jeep-noob said:what percent of these heads fail, I mean i have one and just looked at it, no problem at 85k miles
Thanks, I did overheat in a steep hill, 100+ degree day with A/C on, but I chalked that up to the circumstances i put the jeep in, and reading other threads talking about inadequate cooling inherent to XJ design. I just did a valve cover gasket replacement, and carefully studied the suspected area of the head, but saw nothing, i dont loose coolant either.Dr. Dyno said:It's impossible to say what % of the 2000 heads crack but it does look like a batch of them have been cracking. The problem is that there's no way of predicting which ones are likely to crack. The only thing I can suggest is to monitor the coolant level closely and if there's any unexplained loss, to be aware that this could be an early sign of a cracked head.
All the heads seem to crack in the same place (between the no.3 and 4 exhaust valve springs) but the crack may be too thin to see with the naked eye, so the only telltale sign is discoloration from coolant stains in the place that I mentioned and you can see it when you remove the oil filler cap.
The crack usually occurs from overheating but not always. If you let the coolant level drop too low, there won't be enough coolant to cool the head and that makes things worse. Early detection of the crack and replacement of the head (don't bother getting it welded 'cause it'll crack again) will prevent other damage to the engine.
