Lotus Elise?
as far as auto-x specific - here goes.
the Lotus runs in SS (super stock) in the SCCA events. That means running against C5 Z06's. The Loti have managed some wins in SS in the hands of the very best drivers - Matt Braun, Junior Johnson.
But it seems the Lotus suffers depending on the course design. Wide open flowing courses favor the Vette's. The Vette's do very well in the ProSolo's where launch is important. One of the remaining problems with the Lotus is getting suitable rubber to fit. I still don't think there are suitable sizes in Kumho V710 available so Hoosier has been the tire to run. The new A6 Hoosiers have reduced the gap to the Kumho's - they may even be slightly faster, but wear and longevitiy are yet to be determined. The A6's definitely handle lack of camber better than the S05's or S04's.
I know that Lotus changed the spec on the Elise - I think with MY2006, but possibly MY 2005. The new spec included an LSD. Some car tests I have seen indicate the car is slower in the new spec, but reports from the autocross course are that the LSD is a must have.
There are a few drivers campaigning the Lotus in Prepared classes, FP specifically. Randy Chase and Robert Puertas have been doing very well, but competition in FP is not as close as SS. I believe Randy chose that route so he could run aftermarket wheels that differ in size from stock.
The Lotus will be a blast to drive - as you have discovered, but will require a fair investment to be nationally competitive. I would guess between $10K and $15K. Probably about the same amount to prep a C5 Z06. If you only intend competing on a local level I would not change anything, and just go have fun. See if your local region runs a "street tire" class, and you won't even need race rubber.
If your intent is more toward track days, HPDE's, time trials and driving schools then the Exige is going to be a better choice ( I know your special deal is an Elise, not an Exige) Some sanctioning bodies require a roll bar on open top cars, so check with your local club to make sure your car will be legal for their track events.
The northwest region has a very strong autocross community. We see lots of racers from that region at events all over the country. Check out www.scca.org and follow the link to your local region. There will be a National Tour and a ProSolo held at the Packwood facility in early Aug. Some of our strongest Mini competitiors are from Seattle and Glenn Hernandez is also an EVO school instructor. He can show you how to extract the most performance out of the Lotus.
I've only driven the Lotus a few times. Here is what I discovered.
If you overdrive the car, they will push like a pig. Because the car is so light and tossable, overdriving is a constant concern. They do not like trailbraking, so brake early in a straight line, and be prepared to get on the gas waaaaaay before the apex. The motors rev like crazy, and the powerband is fairly tight at the upper end of the rev range. Not a concern on the autocross course, but on the track you need to keep the motor in the upper rev range. Only noticeable if you are used to Vette's where the motor pulls strongly from idle.
Great car, reasonably priced, not common. Make sure you fit comfortably with a helmet. The Elise is not too bad, but entry and exit from an Exige can be a PITA, and would be a hassle as a daily driver.
HTH
We should start a scca class to run our jeeps in.
How would an Elise stack against an early-mid 90's porshce 911 or C4 cabriolet? or even a newer boxster? I need a truck for work, but have always loved exotics. For some reason I've never looked too much into the Elise, but so far it looks pretty good...
On a track, the Elise would make mince-meat of the Porsches you mentioned. At least I did when I was driving one at the track last time. There were a bunch of really hot cars that the Elise ran away from: 2005 996 Turbo Cab.; 2006 C6 Z51; a quartet of STi's; etc.... The only things out there that day which were beyond the Elise were a 2006 Z06, a race-prepped STi, a Noble M400, an Exige S, an Ultima GTR, and a 600 hp 930 Turbo. Pretty impressive company!
The cars inspire SO much confidence that you find yourself pushing harder than you would in a lot of other cars. The power isn't nearly as impressive as my M3, but they do just fine. The only place I could see my M keeping up with the Elise is on the straight.
For a daily driver? The Elise is not as much fun. That's why I ultimately kept the BMW; it's quicker in most day-to-day situautions and doesn't beat you up like the Elise. Also, make sure you can actually get in and out of them. Even at 23 and 150 lbs, it was challenging to do it gracefully. It's the old AGIF principle for sure.
Anyway, good luck with your search.
-----Matt-----
shite you're kidding...porsche isn't exactly a slouch brand either...more luxury than performance, I suppose? I'm a little surprised...it doesn't make reams of hp...and I would think the power to weight ratio wouldn't make up for it on a higher hp (albeit heavier) porsche...thanks
