LongER travel steering
live24wheel
Phoenix
I've got currie steering right now but it doesnt have enough travel for my setup. I need to be able to get more droop out of it. It is binding the tie rod end at the pitman arm. I was able to find a couple pictures of what i would like to do by putting probabaly two bends in the draglink but they aren't very good pics. Anyone happen to have any other up close shots by chance? Heres what I have found.
Tom,
Over the knuckle setup won't bind like the stock setup.. currie's is a stock style setup just heavier duty. you will need to relocate the track bar to go over the knuckle.
DaveO
Can you put the Currie drag link end in a press and bend it a little to line up better with the pitman arm?
I've heard of folks giving a little bend to the Currie stuff before to get more droop.
I was thinking about that but wasnt sure if it would effect the metal negatively being chromoly. Would it hurt it to heat it up to put a bend in it? Oh hey Dave, Im thinkin about trying to make a couple days of the Draw run... If i can back to AZ for it.
