jeepxj89
- langley,B.C
hey everyone. was just wondering if any of you who have longarms and or have made your own could you post some pics of the build or the finished products? thank ya
jeepxj89 said:hey everyone. was just wondering if any of you who have longarms and or have made your own could you post some pics of the build or the finished products? thank ya
RalphXJ said:search, this is covered like 5 times a day!
But since I haven't posted any pictures of my new toys yet, why not!! Just finished(almost finsihed) a full width swap, and Rock Krawler Long arms! Here are some pictures, still have work to do. I installed the Upper Control arm on the passanger side rather then the drivers side like the instructions called for. Here are some pictures
Still need to cut off the stock lower mounts!
Another inch or so in the back and it should fit 37s nicely!! :wierd:
The rest can be found here: http://www.schwabdesigns.com/jeep/axles/
RalphXJ said:Nope, not driving it like that. That was just after the first day of the install! I still have to weld everything, cut off the lower brackets, and get custom steering made.
jeepxj89 said:about how much would you say it cost to build your own?/QUOTE]
Just the materials for the crossmember and Lower control arms(I use RE uppers) is about $300,up from about 220 when I did my last set(steel has gotten rediculous).
old_man said:Here is a link to what I did. It has worked great and it was pretty cheap.
http://www.4x4getaways.com/LongArms.htm
jeepxj89 said:sorry,your link isnt working
