Long shaft 39 and 34 tooth speedo gears
Also the ones with the 2 wire VSS - 91, 92, and possibly 93.
If your sender is plastic and has 3 wires, it uses a short shaft. If it is metal, has a bit hex on it between the sender body and the transfer case, and has 2 wires, it uses a long shaft.
