I am not recommending this, just throwing it out there so that you understand additional options.
My '90 used the old style Chrysler key set which meant that the ignition key was different than the door key. To fix this I scoured the local pick-n-pull and found a newer model XJ with a key on the floor. Once I was sure it worked in all doors and ignition, I pulled all the locks as well as the ignition cylinder and installed them in my XJ.
This would add additional work since you would have to do this twice (once at the pick-n-pull and once in your XJ) but you would have the advantage of being able to do them one at a time without leaving the XJ with any of the doors unlocked. On the plus side, the door locks and truck locks are easy to remove. The ignition cylinder isn't hard but you will need a steering wheel puller to get at it.
HTH
Todd
