Someone asked me today if my Jeep's vital statistics were posted on
and I realized I had never done that so here goes. Had the Jeep 2 years. 1990 Manual (AX15) 4 door. It started with a 3.5" lift involving coils up front and lift blocks in back on 31" Wildcats. Leaked oil like a sieve engine ran like a comsumptive victorian. Cracked windshield, broken/oil covered seats. Owned by a guy who called himself a "Mechanic" Everything he had "worked" on was broken. DS control arm bushings ruined due to the forcing in of the stock track bar. Paid about $900. (too much but I got lucky) All I knew was that I wanted an vehicle with high ground clearance that I would not have to worry about parking at trailheads and fishing spots. Only thing I knew about XJ's was that I wanted a straight SIX and that a Puegeot gearbox was not a good thing. I found an old tow bar mount that indicated that possibly a good deal of the 262k of mileage on it was was being towed behind an RV and compression and oil pressure was good enough to indicate possibly not the original engine. Probably was an "ok" I was so impressed with it even in the state it was in it was a very capable vehicle.
So now 2 years later.
Engine (has needed the least effort. I love this SIX even the RENIX)
Fixed engine oil leaks (rear seal and rocker cover made worse by a plugged pcv system) Fixed all the faulty sensors/CPS etc and got fuel injection working properly.
Exhaust manifold (Stainless cheap)
AC onboard Air.
Yellow top Battery
Large oil filter conversion
Hard plumbed Oil and Water guages
Starter
Secret cutoff switch.
Hoses etc.
Exterior...
Washer modded and welded OEM tire carrier from the junkyard. $8.95 including the bumper and body brace.
DetoursUSA frame system up front with Superwinch Ep9.0
New windsheild.
Ghetto roof rack using Network Ladder rack. (Rarely used I hate the weight and wind resistance)
Trimmed wheel arches. using comanche rear flares and stock lifted front flares.
KC hilites on the bumper system.
H4 headlights.
Skid Road Tcase skid. (thank you GI John the best part of that purchase was having the honor of meeting you)
OEM gas and front skids.
AJ's Super Rails.
Interior... replaced seats... did a CB.
Drivetrain...
Polished turd up front. Ox locker, chromealloy shafts with Xjoints. 4.10 gears.
Dana 44 rear same gears and locker. Chromealloy shafts.
(this was the toughest thing I have done so far) Got sick of micrometers and dial indicators.
Rebuilt the AX15. (did this as a fun winter project, my first transmission rebuild.) The old one was actually in OK shape but some "mechanic" had installed either the engine or the transmission rather forcefully destroying the pilot bearing and subsequently the input shaft bearing. So now I have a useable spare. Of course did the clutch. Got the AX15, TC and new clutch for $80.
Rebuilt the transfer case and did a SYE. Grand Cherokee 5.2 rear DS.
33/10.5/15 BFG MT Went narrow like them more.
Suspension
Ghetto 5.5 " lift in back. (S10 leaves with a RE add a leaf)
Up front I have RC drop brackets, used Rusty's Adjustable LCA's and RE adjustable UCA kept the 3.5 coils and added some 1.75" spacers.
Thought long and hard about Claytons but got a deal on the LCA and frankly I still like the idea of an axle sort of attached to the vehicle.
JKS quick disconnects,
Rocky Road adjustable track bar.
Rusty's HD tierod.. (I have to say Rusty's stuff makes me think of German engineering without the precision) Heavy duty but a bit sloppy.
Works in progress... Trying to make design removable mudflaps . Maybe will paint it.
hope to inflict more body damage. Thinking about roll cages. Anyway that is my heap.
Hope to see you guys out on the trails.
