GrimmJeeper
- Gardena, CA
can you just get a new piece of glass cut for the bottom and seal the sides with edges with a waterproof cocking/sealant? ive made little frog tanks and lizard cages and its not too expensive to get a piece cut to size. like 10 or 15 bucks
my tank is 4 feet long and 18" high, the glass needs to be at least 3/8ths of an inch thick. As I said earlier paying for the glass to be cut isn't the problem, paying for the glass itself is.
The hard part is removing the old glass from the frame, the stuff that is holding it in is similar to asphalt tar, but its rock hard. I'm really not looking forward to taking the whole thing apart... but it looks like that is what I'm going to have to do. Someone suggested using resin to coat the whole bottom of the tank in a thin layer, I think that will be my next attempt at sealing it up. I only worry though that afterwards if it doesnt work and I do decide to take the whole thing apart it will be nearly impossible with the resin in it.
I have almost a full tube of some super duper aircraft stuff that I can just about guarantee will not leak if installed properly. You are welcome to it. (no it's not pro-seal)
it needs to be 100% pure silicone, any other chemicals in it will leech out over time and kill the fish. there are plenty of great waterproof sealers, but not many of them are suitable for aquarium use. think potable water tanks, it has to be something that won't be harmful for drinking water.
what are the dims of the glass you need? i built a coulple tanks and sumps for my saltwater buddies and have some glass in the garage you could have if you need it, just far away?
the bottom of the tank is 11.5x48 or so. wouldn't know an exact measurement until I get the thing apart. And I couldn't tell you from looking at it if the bottom glass is under the side panels or not :dunno:
