little bit of everything
kraziexj
ks
Misc cleanup. All pictures are here: http://s91.photobucket.com/albums/k292/kraziexj/for sale/
brettm's aw4 manual shifting box, moment switches, on off switches, and indicator lights plus instructions. $65
aw4 100000 miles from 98 jeep cherokee. Worked when removed. Has torque converter, computer, shifter, and shifter cable. $40
np231 from 93 jeep wrangler 23 spline. $40
oval led lights $10
Stock dana 300 gears $40
stock dana 300 rear output shaft, housing, speedo housing and 34 tooth gear $35
two dana 44 spindle nuts from 78 ford $10 for both
jeep cherokee steering box brace $30
1 inch coil spring spacers $15
.5-.75 cherokee coil spring isolators can be stacked for lift $10
ruff stuff anti-wrap spring perches 3.25 diameter but could easily work for .25 up or down. $15
1310x1330 conversion u joint spicer brand new $10
1- 29 spline 8.25 axle shaft (left and right are the same length) $20
4 never used 5/8x3 diameter round u-bolts $20 for all 4
2 stock 98 jeep cherokee seats. Mounts included. some small weld burns, and some spray paint over spray. $15 each
cj offroad ax-15 dana 300 adapter spacer + dd machine clocking ring (clock up or down) Studs, and counter sunk bolts all there, but missing 2 lock nuts $35
