morgan320i
- oakley
So my 89 xj 4.0 has had this mysterious oil leak coming from the head gasket, i replaced everything, every gasket there is and no luck, so im replacing the head gasket, i am getting the head reserfaced, when i took the head off lastnight i noticed a ton of oil build up in the oil gallies near the lifters, how can i clean this area without removing the motor, i am also replacing the lifters/pushrods cause all that buildup i dont trust it, whats under the lifters besides riding the cam? Can i pull all the lifters and flush with oil all the crud down the holes then remove the oilpan to get it out? Or drain plug?
