ReBeL XJ
- spring hill tn
wow! all i have to say is i will never do that again. anything and everything that could go wrong... went wrong. i bought a 3in Rough Country lift. 1st mistake... i bought it used. coils spring up front were a sinch. we had that back together in 2 hours. but the rear sucked! we had to go buy new center bolts from the local spring shop but... 2nd mistake... we didnt check the bolts on the leafs to see how wide they were. so we get back to the shop and tear the rear apart. we went to go put the bolt in and it was too wide! so we decided to pull the leaf pack out and drill it out...3rd mistake... came out pretty easy. so we put it up on the drill press to drill a bigger hole in it. broke 3 bits. said F$%* it and went to auto zone. we bought a 3in block kit and went back and put that on in 10 mins. then we put the new shocks on the rear...4th problem... one of the shocks is longer than the other... so we put those on and put the rear back together. then we took her out for a test ride. we found a nice lil place to flex her out and see what she could do. i flexed out on the rocks and put it in park...5th mistake... i opened my door... or atleast tried to. the mug would open. i thought i had broken a door hinge so we took her back to the shop and called it quits for thenight(130 am) next mornign we look and see that the drivers side front fender was dented in and stopping the door. so we used a pry bar and pulled it back out. i've driven her all day and shes done great. a lil ruff on the highway cause it needs an alignment but other than all of the above its good. will post pics tomorrow. and later ill get pics from Summer town on new years.
sorry for the long post.
Todd
Todd
