YELLAHEEP
- Littleton, Colorado
Not to argue, but I've done the drill thing. Worked like a charm. The pinching of the brackets is kinda the problem, but you can also shim it with a washer between the two brackets if the door needs to be adjusted up or down to hit the striker a bit better.
The whole idea is to get the 2 hinges to pivot on the bolt/pin with no slop around the pin. By drilling the holes to a uniform size, with a pin that fits snug, you'll get the door to swing on a level plane.
Ya dig? :thumbup:
Ya dig? :thumbup:
