MattAlpha
- Marina, CA
I've got a new set of fiberglass leaf springs and Prothene bushings that I'm attempting to install. The only problem is that three of the shackel bolts don't seem to wanta leave. The first one (upper shackle bolt on the driver's side that goes into the frame) I got out without too much difficulty (after I overpowered the loctite with a breaker bar). The others I was able to get out to the point that the threads were not longer in the frame, but the bushing and its metla sleeve would turn with the bolt but the bolt won't come out any further.
If it didn't bolt into the frame I'd use something to push it through, but that's not possible. So I've tries to pry them out with no success. I don't have a plasma cutter or anything that cool to cut them out.
Does anyone have any ideas?
Thanks,
Matt
PS: I have pics to post of them, but I can't figure out how to put them into this window.
Thanks,
Matt
