- Westminster, SoCal
ok, I'm replacing a set of used tomkens that I picked up not too long ago and one is kind of bent and my XJ is leaning too one side...... Whats going in is 3.5" RE
Anyways, so I'm doing them... and I realize that they have a bigger centerbolt so I have to drill out the hole in the perch (pad? the thing on the axle)..... from the looks of it 9/16" head.... so I go and hit up Home Depot.... well, they are out of any bit that's bigger then 1/2"!!!! ok, I'm off too lowes, I get a 9/16" and I get home happy, I realize it's 1/2" on the drill end... I'm almost ready to hit my head against the wall when I realize that I do have a 1/2" drill that I bought a while ago and haven't used yet..... ok... I get that, I drill out the hole just to find out that the hole is s till a hair too small... ok, here come a dremel.... I dremel the hole out a bit to find out that the spacer they put on the spring is just enough wider that it won't fit so I dremel the hole out a bit more and even out the spacer around the bolt..... then I realize that the bolt with the spacer is just a hair too long for me not to be able to fit it in even with a shim! ok..... I slice the head off a bit (1/8" or less). ok... so now I'm sitting pretty although my arms are hurting by now from wrestling the spring on and off on and off on and off.... ok, I grab the ubolts I picked up at ppepboys and that I have used previously with the tomken springs and as I tighten them per fsm to 56ft lbs, I realize something feels funky even though they seemed to get on nicely..... ok, I try to loosen them up and nothing!!!! (before I was able to loosen them up with a small ratchen)...... ok, here comes the breaker bar..... and one comes off, while the other has to be cut off as both have just stripped themselves off!!! the thread must be too fine and the springs too stiff for them!!!! So I'm throwing in the towel for the night and I am hoping that I can find pickup some ubolts on my way to the wedding tomorrow!!! and that's way up in ventura GRRRRRR at noontime so I gotta leave home early enough to get the bolts and still not be late! There is no way in hell that I will ever help anyone with leaf springs in the rear.... I'm just too unlucky!!!
Also I have a feeling that the rearend will kill me as when I was working with the tomkens 2 weeks ago (trying to figure out the reason for the lean) I somehow dropped the axle onto my middle finger in the right hand and crushed the hell out of it.... it finally is a useable shape and size and but after two weeks it still ain't looking too good...
Remi aka Kejtar
Remi aka Kejtar
