COjeeper
- Colorado Springs
For awhile now I have wanted to upgrade my doors on my 95 to some late model doors. My reasoning being I already changed the console out to a late model one with cup holders and I was tired of hitting my head on the window track on my split window when wheeling. So I started looking into doing the swap. I searched a lot of forums and only found a few articles on doing the swap, but nothing went into real detail. So I set out to do a write up on it in the hopes that anybody with the slightest mechanical and electrical skill could do this.
So with that being said, I went looking for some late model doors and everything needed to do the swap. I headed off to the local you pull and pay and found the front doors off of a 97 that was the same color as mine, well not quite exactly a match, but I plan on repainting them anyway, so that really wasn't an issue. I lucked out and found doors that still had the internals and the passenger door had the trim, but not the driver door. Not a big problem at the time, I figured I would come back and find another one when the time came to needing it.
When grabbing the doors make sure to grab the door strikers from the late model as well! I forgot to and had to go back and get some. :doh: Don't forget the backing plate inside the B column as well. I ended up having to take the trim off the B pillar, the seatbelt mechanism out and had to cut some of the sheet metal out of it to get at it.
Here is what you will need to make it work. The backing plates I used were from a TJ if I remember right. They are the zinc colored ones in the upper right in the picture, the ones off of the late model are the ones on the lower left. The TJ ones are way beefier as you can see and that is the route I went.
When I grabbed the doors, I cut out the door plugs as well. I cut as much wire as i could after the plug on the vehicle side of the wiring so i had plenty of wiring when it came to tie it all in. I was only able to use the 3 white plugs on the drivers side do to the passenger side plugs were tied right into the fuse panel. For the speaker wires, I cut the plug off the old door and wired into the new door.
Now that I had all the parts I needed, it was time to preform surgery. I started by taking off the old doors. I didn't take any pictures of this process, as it is pretty straight forward. Other than being a pain in the arse getting the 6 bolts out of the hinge going into the door, everything is pretty easy. Ended up having to heat up the bolts to get mine out. When reading bout this swap, I read some conflicting information on whether the doors would swap. There is a difference in door hinges between the older Cherokees and the newer ones, but both doors bolt up to both style of hinges so don't be alarmed.
Once I got the old door off, I began to hand the new door. This took me awhile to do, especially by myself. Trying to hang the door and bolt it up at the same time was a pain in the arse. I would highly recommend the help of a buddy, definitely would have made it a lot easier. :banghead: I ended up having to mess with the shims to get my door body lines to match up, that and a little persuasion with my body weight hanging off the door helped out quite a bit. I took my time with this step because I like clean lines and I am pretty anal when it comes to things like that.
