Roxtar
- NW Indiana-Chicago area
Does anyone know what is the largest size elect fan that will fit on an XJ?(keeping the stock aux fan)
jeeplas said:If you are going to be at the BBQ on Sat. you can ask Sean about his. He has two fans that are run by switches inside, one is the stock fan.
Planetcat said:The flex a lite 110 is about the dimensions you want for an aux fan. See the flex a lite website for the actual dimensions. As for the go jeep article on the flex a lite 110 install, take it with a grain of salt. It's not the silver bullet solution that the article portrays it to be. The belt driven clutch fan will always pull more air than a 1250 cfm electric fan. I'm one of those people that installed it and then uninstalled it and went back to OEM clutch fan.
What are you talking about :confused1Planetcat said:The flex a lite 110 is about the dimensions you want for an aux fan. See the flex a lite website for the actual dimensions. As for the go jeep article on the flex a lite 110 install, take it with a grain of salt. It's not the silver bullet solution that the article portrays it to be. The belt driven clutch fan will always pull more air than a 1250 cfm electric fan. I'm one of those people that installed it and then uninstalled it and went back to OEM clutch fan.
