- Westminster, SoCal
fatwreck said:I know you said you already bought a new converter box, but I've only had luck with one brand. The other ones that I've tried.....they may look the same.....and have the same number of wires....including a ground....but they won't work.
It ends up just as you described.....turn signals only work when the brakes are on.
We've had the best luck with the Draw-Tite ones. Rewire it and everything is good to go.
Sorry I don't have a better answer for you.
Brian
www.projectxj.com
www.formattfab.com
If you're having problems with the converter boxes then you can make one for each side for way less the $2 in parts. All you need is diodes and resistors. The only tricky part is choosing the right resistor to control the brightness of the light (might want to buy a pot first and play with that and once you're happy with the brightness levels measure the resistance and buy that resistor).
The light that you're using: is it a proper stop/turn light which has 2 wires to drive it and one ground or does it only have 2 wires altogether (one for power and one for ground).
This is what you would need to make one that works with a 2 wire (ground and signal) setup.
http://home.socal.rr.com/remi/pics/3to1lights.JPG
The blinker is the brightest so that when you're braking it goes to a brighter mode and that's why it doesn't have a resistor. Next one is the brake which needs to be brighter then the running tail light, so it's resistor needs to be smaller then the one that you use for the tail light signal.
