Klune V & Warn Hub Conversion
Ben H
Fresno
Hi guys,
I have a couple of parts lying around that I'd like to get out of my shed.
The first part is a Warn Hub Conversion, the big 5x5.5 conversion, essentially gives you Dana 60 30 spline outers. The kit is complete and has only been use offroad. Comes with a spare trail hub and spare warn 30 spline stub shaft. As I said, this kit is complete, with machined rotors, stub shafts, hubs, spindles, bearings and a brand new $120 set of spindle nuts.
This kit will help eliminate front driveline vibrations by getting rid of your unit bearings for your Dana 30/Rubi 44. This kit also makes the weak link in the front axle the outer hub, which can be replaced in about 5 minutes, saving you the trouble of replacing ujoints, shafts, ball joints, locker, gears on the trail. This is a bolt on mod for most Dana 30s and TJ Rubi 44s.
When I originally bought the kit about 5 years ago, it was retailing for $1,400, not including the spare shafts, spindle nut, or hub.
I'd like to get $900+shipping, but of course this is best offer.
I also have a used Klune V Underdrive unit. It is a 2.7:1 unit with a direct shifter. This will give you a 4 speed tranny. It is a 23 spline in, 23 spline out unit. Will fit most all YJ, TJ, XJ, JKs with 23 spline output trannys. Comes with spacer, mount, shifter and underdrive unit. It will add 6.5 to 7.5 inches (depending on spacers used) to your drivetrain and is an easy install between the tranny and tcase. I paid $1,200 for this about 6 months ago, but decided to go another route. Asking $1,100+ Shipping.
PM me if you have any questions or are interested.
Thanks,
Ben H.
Klune is sold!!!
Will consider all reasonable offers on the Hub Conversion.
