KinesthesiaDrums
- Minot, ND
awight...first off specs- 1990 XJ Laredo 4.0 2WD 4 door
i been searchin all day and didn't really find a thread with a clear answer to my problem......this past weekend i lifted my jeep with Rough Country's 4.5 w/ AAL.......did front end friday night, and rear on saturday....i am more than happy with the ride height and the ride quality. Yes, it's kinda "Rough" like all of you said it would be, but it's that sporty, stiff, bouncy rough that i kinda like...i'm weird...so what? lol.
anyways...the front end is great...it's the back end that i am kinda concerned about....it sits about 2 inches lower than the front......i took the Heavy Duty stock spring pack out of a 1989 laredo XJ with the factory towing package to put the AAL in on this jeep (the stock leafs on this jeep had sagged to much negative-ness)
so this lift kit came with the AAL's and 6" long drop shackles....
i want the back to come up to be level with the front, if not an inch or so higher.......
i installed the AALs in the leaf stack where i saw other write ups say to...the instructions weren't too clear....but the AALs are at a kinda odd length....same leangth as lower leaf at one end, and longer at the other....
pictures:
so yea.....i guess i probly should have bought an entire new leaf pack (like most of you suggest), but i figured using the factory heavy duty springs might help avoid that....soooooo i don't really have the money right now to go buy new full spring packs.......(looking at getting RE when i do...yay, nay?)
what can i do????
are there longer shackles i can use.....i don't really wanna go to blocks...heard too many bad things....my dad looked at my spring packs and said i might have the AALs in backwards......is he right?
oh, and btw.....this rig IS only 2WD....so whatever options i can do, there won't be much, if any, real offroading done with it...
axle question.....
i posted my question at the end of a similar thread (2nd page)....since there was already one, i didn't really wanna start a new one....but it doesn't seem to have been noticed.....so if you guys could check that out for me and give some advice, i'd really appreciate it....
http://www.naxja.org/forum/showthread.php?t=34342&page=2&pp=15
-thanks
pictures:
what can i do????
axle question.....
-thanks
