BIGSLVRXJ
- Des Moines, Iowa
Hey guys,
1998 XJ, AW4, NP242, D30, C8.25
It's been a while since I've asked for help in the tech forum but this has me stumped. I just bought a 1998 XJ that was advertised as having a bad transmission. The old transmission was already removed when I got it and there was one from a salvage yard included in the sale. The salvage yard trans was supposedly good and had 120k.
I noticed when I was prepping the "new" trans to go in that the torque converter was low on fluid, not to the top like they usually are. Like a dummy, I forgot to add fluid to it before putting it in, but I don't think at this point that that could cause the problems I'm having.
Here are my symptoms:
-I have now added 7 quarts total of fluid and it will not engage in any gear. When the shifter is in gear it idles up like it's going to engage but it doesn't. I have cycled through all the gears and the fluid level is between the two holes on the dipstick when warm.
-It grinds when going from reverse to park but it won't grind if I go straight from Neutral to Park.
I'm starting to believe that there is an issue with the transfer case. When I was doing a fluid change on the transfer case I stuck my finger in the drain hole to try to hurry the fluid along and I noticed something move. I pushed it about an inch to the front, it sprung back, did it again and it got stuck and didn't spring back. Is that the chain?
Also, now I am relatively sure that the case is in "Part Time" selection but the Jeep will roll forwards and backwards like it's in Neutral and the transmission is in Park. So I don't know if I managed to shear the park pin or if the case is at fault.
So in my mind I have narrowed it down to 3 things.
-Transmission needs more fluid and just hasn't cycled it all the way through. However I would think 7 qts would be enough.
-Transfer case is shot.
-Transmission is shot.
Any thoughts?
Thanks in advance for reading my long winded post, any help is greatly appreciated!
-Collin
Any thoughts?
-Collin
