Just Another XJBuggy
freerider15
FoCo, Crawlorado
So I'm just going to continue my build here...at least for the mean time.
So it has been a while....but UPDATE TIME!
Got my cable shifters in...went a little long and a little too thick I think...these things are BEEFY!
As well...got my cutting brakes and brake pedal assembly/diaphragms in :clap:
I'll let the pictures speak from here, but got:
-Top of the rails skinned
-Steering wheel column mounted
-Passenger side floor skeleton done
-Started cleaning up the wiring and running it through the fire wall
-Got Computer and Fusebox mounted
-Supply & Return coolant tubes bent up, run & mounted
-Other small stuff
Those brake parts will never work, just give them to me and I'll put them to use. :D
Its looking good man, definitely a crazy build.
Nice, I recognize the XJ firewall.
I don't know what you guys are talking about...there is still SO much XJ in this...
There's the uhhh...ummm...ehhh...firewall!...kinda. Oh, and there's some frame rail still there...somewhere!
:D
Just wait until you guys see it skinned...thats when it shall look bitchin'
:greensmok
You're gonna have to quit calling it a buggy Justin. This thing is rapidly approaching Rock Rod status......
Rock Rod? :D
'Nother update:
Got the boatsides "done". Still need to do a hair bit of cutting, fully weld it up, and dimple the holes. The boatsides will be covered in 1/2" UHMW later on in case anyone was wondering.
Got the cutting brakes and brake pedal mounted:
Better shot of how exactly its mounted...and the engine cage bar (engine cage and front ORI remounting to come soon)
Got some of the cables mounted and run. Man WHAT a PITA that was!
Working on getting the rest of the driver's floor done:
Now what you see in this picture should help...ohh...get the motor fired in the next couple weeks! Its two orders, one from Delcity and another place I would highly recommend, VTEWarehouse. VTEWarehouse had by far the best pricing on BUS bars, covers, and more. In the picture are two kill switches (one of which I painted).
And last but not least, and overall shot of how she sits currently:
I've got a sweet set of 42" Iroks on some ultra custom 17" beadlocks that would look killer on that thing. I'm just saying. :)
Also been done since the last update (will have pictures soon enough)
-Lots of wiring work
-Ran + cables (with 2 inline kill switches)
-Ran - cables
-Got some floorboards made
-Chopped/Shaved the 14 bolt
-Ran all my fuel lines
Might have forgotten something...but if I do i'll make sure to include it :D
Going to try and get the 14 fully done this weekend by getting the gears installed and the brakes on.
