VAhas...
Thanks for the kind words. I can try but take this with a grain of salt as it's basically the result of a bunch of reading and a touch of practice. I'm operating on some basic rules of thumb and the assumption that the factory generally did stuff right to give me a baseline. Then, if I can keep the system ratios similar to stock, I should be good. This gets harder if you're starting from scratch but I'll try to help.
From the most basic... Any brakes that are powerful enough to lock up the tires are powerful enough. If you're dealing with a race car (or any other repeated heavy braking environment) thermal mass comes into play. For 4x4 stuff we mostly care about power, not brake fade so I'll set that aside. Assuming your brakes are powerful enough to lock up at least some of the tires and the fronts lock up first, you'll slide in a straight line (plow). If the rears lock up first and you're turning at all, you'll spin. That's why we always want the front to lock up before the rear.
That said, performance braking is all about getting the REARS to carry as much of their share of the braking as they can. That one statement in a nutshell seems to be the #1 secret of braking. At the same time, it isn't super intuitive since the rears might only be 20% of the braking potential under heavy brakes given weight transfer. However, if the fronts are at the threshold of skidding either way, it's all about getting the rears to do the 20% they can (without sliding first) rather than the 10% they might try to do if your system isn't set up right.
Make sense?
Getting the brakes to share load well between front and rear is first about sizing the parts and second a function of the proportioning valve. First a couple notes on braking power. Braking power is a function of the total ratio of force into the pedal vs. force exerted at the contact patches. That means we have to consider the following factors affecting system gain (power):
-Leverage of the pedal vs. master cylinder rod.
-Power from brake boosters
-Hydraulic ratios of master cylinder (dual piston in a single bore) vs. slave (aka caliper) cylinders
-Coeffecients of friction of the pads
-Radius at which force into rotors is applied.
All of the above gives us the potential twisting force (moment) into the wheel assembly. However since this is a torque, you divide by tire radius to get the horizontal reaction force you can put into the contact patch. Even without the extra mass this is why bigger tires put strain your brakes and it feels like the power has gone down.
We're only really going to play with a few of the factors above. Most folks aren't changing the pivots on their pedals to get more system gain (but you could). Boosters will affect the overall system power but don’t do much for a front to rear balance (great thing to go after if you have weak brakes though). They’re a bit of a black box if you ask me since there’s some internal valving that matters, but generally diameter and number of diagphrams are a good indicator of power.
If I were designing a system nearly from scratch in a 4x4 I’d keep the OEM pedal geometry, pick a booster with matching master cylinder from a vehicle a couple classes larger (which it sounds like you did), then pick from the options available for rotors and calipers trying to keep the front and rear diameter/piston sizes in the ballpark of a known vehicle, and finally fine tune bias with pads and prop valve. The reason I’m spending all this time on the build up is to point out that if you have the wrong calipers/rotors in too dramatic a ratio (say way oversized rear caliper pistons), the prop valve can’t compensate and you’re SOL.
To see if you're in the ballpark, I tend to start with an existing OEM design and compare from there. In this case what we care about are overall power and the balance of force between front and rear. As such, it becomes a game of balancing ratios. If you throw a big brake kit on car that gives you 20% more leverage due to increased diameters--all things being equal--you'd want to either increase the force in the rear by a like amount (can be a combination of rotor diameter, piston area, or pad coeffient of friction) or else decrease the piston area on the fronts by 20% to compensate. However the later would mean you didn’t increase braking power so that added diameter only helps with thermal mass (brake fade). We’re putting on big tires so we want to up power at the end that needs it.
You might consider putting together a little spreadsheet on a known 4x4 with 4 wheel disc brakes and start comparing ratios. Grand Cherokee might be a decent place to start. At some point I’ll end up doing this for my FJ40 since it’s using front brakes on the rear axle. You do this for front and rear and compare. I seem to recall fronts generally run a bit bigger so let’s a say it works out to total of a 3:2 ratio.
So that brings up back to the prop valve. Under light braking the tires theoretically COULD share about 50% of the braking force if give or take 50% of the vehicles weight is on each end (round numbers again). This is a good thing on a street car because you can slow the vehicle with less effort and get more even braking wear. However, the harder you brake the more weight shifts and any tire can only exert the cofficient of friction of the contact patch times force normal (weight of the vehicle on that tire) before it slides.
Without a prop valve, using the 3:2 ratio I suggested above, the front tires would always see 60% of the effort and the rears would always see 40% of the effort (not quite 50/50 optimal, but we’re rarely braking that lightly anyways, there’s always some load transfer). However if we’re braking hard, particularly with our higher CGs, it’s easy to get a great deal more than 60% of the weight of the car onto the front tires, and the rears would skid first. No bueno.
Proportioning valves are pressure limiting devices. That’s why they’re only ever installed on the rear brakes (never want to risk limiting pressure to the fronts). Each one has a setting after which they start limiting the fluid pressure reaching the rear brakes. It’s a curve (and the point of major change in influence is called the knee point). The few OEM prop valves I’ve tracked down info on maxed out their influence cutting the pressure down by ~1/2. Now suddenly our theoretical setup with ratios that started in the 60/40 range can operate in the 80/20 range when you’re on the brakes hard. Cool.
So back to the XJ/ZJ prop valve question that started all this. Why would you change a prop value? You’re seeking to change the amount of pressure limiting the valve does to better align to the system gain ratios of all the other parts used.
Compare the two internal prop valve springs in the picture I posted above. The wound wire is pretty similar diameter, similar free coil spacing, dramatically different length. Because they’re compressed into a similar void the longer spring is going to be exerting a lot more pressure on the fluid passage before the fluid is reaches high enough pressure to compress the spring, move that piston within the valve and allow whatever influence on the fluid pressure it does. Now I didn’t do the math on this, but by inspection we can tell they’re dramatically different in how much pressure limiting they’re going to be doing… which affects the ratio of front to rear braking, which affects how much work the rears can be doing, which affects how quickly I can stop.
If we did try the math on the ratios of wheel cylinders and leverage for drum brakes vs. disk brakes and piston area, we could figure out if it’s up or down, but in this case I don’t really care. My guess would be the lighter ZJ spring makes pressure limiting come into play sooner which means the ZJ brakes are inherently more powerful and have to be kept in check. [and F-me I just noticed I posted them backwards above, ZJ is the shorter... damn
's no after editing policy!!!!!] However, I could easily have that logic backwards and I can't remember if the reviews by others had the rears as too strong or too weak without the change. I can say that the brake systems on the XJ and ZJ are otherwise pretty similar so Jeep seems to be using a change in the prop valve to compensate for the differences in the brake system power between drums and disks for the relative system gains of the parts in use. Just knowing that means we have a shot at being in the ballpark and meant I definitely want to run the alternate prop valve internals. Even then, it'd be safer to run the whole thing, since subtle changes in hydraulics matter, but that was a great deal of extra work so I went with the wisdom of the internet and did internals only. Looking at it, you might be able to do spring only, but I had the other bits so why not?
The thing is, without knowing which calipers you’re running where (and tracking down specs on the caliper pistons) I can’t tell you if a prop valve change would be good for you or not. It’s not just disks vs. drums either. If you went from Jeep disks to a GM drum (not that you would, but just as a point of argument) and the GM drums happened to use huge wheel cylinders the change in the prop valve could take you in the wrong direction (hence why it’s worth doing some comparison to known vehicles.)
When in doubt if your rears lock up first, try a pad with more bite up front. You could also jump to an adjustable prop valve (biggest downside with those tend to be manners under light braking, you might not care). If the front locks up first, you’re safe but leaving braking power on the table. If you don’t have enough braking power period, then upsizing both ends can be done via added leverage (rotor diameters) or increasing caliper piston sizing (clamping force via hydraulic ratios). Upsizing booster adds power via vacuum assist. Master cylinder changes and pedal leverage changes affect both power and how firm the pedal feels.
That turned WAY WAY longer than I intended but it was a least entertaining to write. Hope it helps.
-Joel
