what size you lookin at, that would tell ya, if you get 2 inch acos get 1.75 shackles and when you put it on, take out the stock isolator and the lift should be about even
depends on what size, bigger than 1.25 id say youd be runnin into some death wobble and fender rub because they are used to set the axle in the right spot in the well
