HollisM16
- Colorado Springs, CO
Hey all,
So I'm finally getting Phase II of my XJ done, decided to have the pros handle this portion since I'm not a welder (Tanner 4x4 here in Colorado Springs is doing the work). Here are the specs for upgrades from my current setup (in sig):
- Front Currie high clearance HP Ford 9", trussed for JeepSpeed, ARB, 31-spline chromoly shafts (5x5.5, 4.88's)
- Rear Currie Ford 9" with truss, Detroit locker, 31-spline chromoly shafts (5x5.5, 4.88's)
- 35x12.50R15 ProComp XTreme AT's, using 5x5.5 versions of current wheels
- Going to 14" Fox 2" racing coilovers with reservoir in front
- 2" Fox remote reservoir shocks in the rear with air-bump bumpstops
- Custom front bumper (a lighter Trailready style) which ties into an engine cage, coilover shock hoops, and a better-than-stock skid plate
- 1-ton steering (with custom track-bar for coilovers)
- Anti-rock front anti-sway system
- Bushwacker cut-out flares (using real nuts and bolts)
- TNT-style unibody stiffeners and slider/door guards (custom though)
- TNT customs Y-Link long-arm system and HD bellypan
- Reinforced steering box
- Reinforced rear spring mounts (boxed)
So my question is with the long-arm setup and coilovers tied into an engine cage, would I need the TMR-style reinforcements (seen HERE) or do you think I would be okay for light jumping/baja-style riding?
Ride height will still be about 5" higher than stock. I'm trying to keep it lower with larger tires, great droop, and improved on-road handling. Thoughts?
Obviously I won't be racing this since I'm not adhering to JeepSpeed rules. And I know, I still need a full interior cage. I'll be doing that (8-point) along with Deavers, an HID light bar, a winch, and a custom swing-away tire carrier in the next phase- probably next summer. Maybe even a paint job... which many say should have been my first order of business. LOL
Pics or it didn't happen? Probably early next week. =)
Peace,
Hollis
Peace,
Hollis
