Does it put any abnormal wear and tear on the motor? I mean, obviously it does, but I'm talking in terms of engine life. Is this thing gonna make your rig need a powerplant in half the time of running it stock, or is it not that drastic?
That is a sweet setup. Can the wastegate be adjusted up for a little more boost? I assume you need to run premium to use the boost. Why are you taking it off?
Hmmmm where in CT are you? I would be interested in going to take a look at it. I am in West Suffield.
you dont want to go up any more than 8psi at most... 6-8psi is the highest you want to go for premium fuel's on a turbo.
personally for a jeep i'd rather go supercharged... power doesnt come all of a sudden as soon as boost hits like on a turbo
Thanks for contributing but none of what you posted is true. A properly sized turbo brings the power on where ever you need it. You can run more than 8 psi. PSI is not a good gauge of what a motor will take due to turbo sizing. Its all about CFM.
I build turbo kits for all manner of vehicle. This isn't the first kit I have built.
this is incorrect. My WRX made in excess of 400WHP, at 20psi, on 93 octane.you dont want to go up any more than 8psi at most... 6-8psi is the highest you want to go for premium fuel's on a turbo.
this is correct, sorta.. SC boost is linear and instantaneous, whereas turbo boost is not.personally for a jeep i'd rather go supercharged... power doesnt come all of a sudden as soon as boost hits like on a turbo
