Thats interesting about the MPG, having the conflicting results of MPG dropping after 55 or 65:
The ignition timing was also interesting, thanks for collecting that data. I had just assumed that max advance was 36, but it appears its as high as 42 under lean cruise as you stated. Two areas at important, the lean advance for maximum MPG under cruise, and a under full load(low vacuum , high RPM). Can you log advance, at some reasonable refresh rate? It would be interesting to see a WOT run, what advance it maxes out at, and how soon it reaches that max. I'm guessing 32 degrees at maybe 3000 RPM, mind if you get a change, checking that out?
I made lots of progress on my computer, but it will have to wait until this semester is over until I can do more work on it. I going to made a circuit to input the VSS(vehicle speed sensor) to my computer(MegaSquirt) so I can figure out gas mileage. I need a frequency to voltage converter IC, which I will have to order. Then I can start posting finds of my own.
This is really interesting stuff
