Jhumphrey
- Nashville, TN
So Im getting ready to order some sliders for the jeep. I havent decided on which "stage" slider yet, but I know Im going to order JCR. They have 3 different stages (here). What all do you suggest there? I was thinking of just going with stage 1 to keep the neat and clean lines of the xj, but thought maybe the 2 or 3 would give better protection against "close" objects on the trails. Stage 1's do stick out some as well.
My next question is about stiffeners. I was thinking of getting either TnT or HD (most likely HD, it's the way Im leaning right now). The question is, are they needed if I put the JCR sliders on? The sliders bolt to the unibody and pinch seem (install page), but have a fairly large gap in between contact points. I also read on Pirate that under body frame stiffeners offer some protection against "tuna can flex", but that you only really gain the benefit if you cage your xj. Since I move people and equipment with mine, I have no intention of caging the xj.
Basically, Im getting the sliders regardless. Im just trying to figure out if the stiffeners are worth putting on or not. I plan to do the work myself (welding with the help of a buddy) and I heard that its "iffy" on welding the unibody because of its thin sheet metal composite, so Im a bit weary of it right now...
