J Money
- Yorba Linda
So here is my build thread… There is finally light at the end of the tunnel. I wanted to build a super clean/bulletproof pre runner that retained front/rear seats, carpet, AC and Stereo.
Front Suspension:
· Deaver Jeepspeed Coils
· Fox 2” Stroke Bumps
· Fox 2.5” 3 Tube Bypass Shocks (10” Travel)
· Rubicon Express 1660 Extreme Duty Track Bar
· Rubicon Express Track Bar Bracket
· Rubicon Express Track Bar Brace
· Rubicon Express Drop Brackets
· Rubicon Express Lower Control Arms
· Currie Upper Control Arms
· Currie Jeepspeed Tie Rod/Drag Link
· Patriot Fab Works Upper Shock Mounts
· Patriot Fab Works Lower Shock Mounts
· Heavy Duty Steering Stabilizer
Rear Suspension
· Deaver G9 Leaf Springs
· 2.5” 3 Tube Bypass Shocks (14” Travel)
· Patriot Fab Works Bolt In Bed Cage/Sub frame
· Custom Poly Bumps
· Rubicon Express Boomerang Shackles
· Patriot Fab Works Lower Shock Mounts/Spring Plates
· Patriot Fab Works Spring Hangers
Chassis
· Custom 4130 Chromoly Frame Plates
· Custom 4130 Frame Stiffeners
· Patriot Fab Works 1.75” Bolt In Roll Cage
· Rear Frame Rails Notched for Awesome “Gnarticulation”
Other
· Chromoly Front Bumper
· Chromoly Rear Bumper
· Detroit Locker
· Superior Axles
· Power Slot Slotted/Drilled Brake Rotors
· Goodyear MTR Kevlar Tires
· Aluminum Radiator
· High Flow Water Pump
· FF Dynamics Triple Threat Electric Fans
· 1999 Intake Manifold
· Hedman Ceramic Coated Header
· Soltek Lights Converted to HID from Baja HID’
· Auto Pal Headlight Conversion
Stuff to Get Done in the Near Future
· Front Seats
· Harnesses
· Custom Sheet Metal Console
· Gauges
· GPS
· Race Radio/Intercom
· Dynamat the Whole Thing
More Pictures to Come.
I have to give a big thanks to Mike over here, he's got fab skillz for days.
Front Suspension:
Rear Suspension
· Custom Poly Bumps
Chassis
Other
· Detroit Locker
· Superior Axles
· Aluminum Radiator
· Front Seats
· Harnesses
· Gauges
· GPS
