Is This Exhaust Flange Gasket Installed Correctly?
Hmmm.. Hard to tell from your pic but maybe the gasket's in backwards. The flat side goes against the manifold and the "tapered" end slides slightly into the downpipe.
However, if it's not leaking, leave it alone. Maybe snug up the bolts after a few heat/cold cycles.
It does look backwards. Could just be the picture.
The tapered side is towards the downpipe so I should be good. Thanks!
