XJ-Mayhem
- San Jose, CA
I'm hoping some of the RENIX wizards can chime in on the health of my 90 I just picked up, and maybe give me some direction on where to head next.
I've been working through Cruiser54's list, so far I've only done 1, halfway through 3, 8, 11, 14, 31
As for basic automotive checklist on a new used vehicle... I've only changed out the plugs for the Champion N9YC's and reused what looked like new wires from the PO. I still need to do a full fluid change.
It idles a little rough when cold, almost sounds like it has a big lopey cam, and it smells rich. The plugs helped it smell less rich and smooth out, but didn't fully take it away. It also will occasionally stumble for a second before coming back up while cold. It's been 12+ years since I've had a Jeep/my last RENIX, so maybe I'm expecting too much when I'm thinking a kitten pur idle? PO hacked off the muffler, I think I can smell the CAT is bad, and I think I can hear an exhaust leak towards the front - assuming manifold has a crack.
Anyways, here's the information dump from my REM II in the order it presents it. The initial numbers are cold after just starting, and the 2nd/3rd numbers are if they changed after warmup/a drive around the block
16-17 Hg of vacuum
12.8 Hg of MAP vacuum
1.6-1.8 V at MAP
30.0 Hg BARO
90* Water - 180 * Water - 210* Water
65* Air - 108* Air - 138* Air
13.5 Battery
13.8 V O2 Heater - 13.6 - 13.3
1.9-4.8 V Oxygen - 2.4 - 1.78
14.8-16.0 Air/Fuel - 14.9 - 14.7
Rich Exhaust - Rich - Rich
Closed Exhaust Loop - Open - Open
Off EGR - Off - Off
590-700 RPM idle - 590-650
116 IAC Turns - 109 - 64
17% Throttle
0.88 V Throttle
Closed TPS mode
5.6-6.0 Injector M/S - 5.8 - 5.5-6
0.6 Cold Enrich - 0.0 - 0.0
70-120 Short Term FT - 128 - 128
128 Long Term FT - 128 - 128
0 knock - 0 - 0
14-15* spark advance
0 retard
16-17 Hg of vacuum
1.6-1.8 V at MAP
30.0 Hg BARO
13.5 Battery
Off EGR - Off - Off
17% Throttle
0.88 V Throttle
Closed TPS mode
0 knock - 0 - 0
0 retard
