Beezle
- thornton CO
Sooooo, I decided to try out the airsoft BBs in my 33x12.50 MTR Kevlars because they had to use a lot of lead weights to get them to balance right. I've read a lot of good experiences with the airsoft BBs so I went for it.
I used 8oz per tire according to the dyna bead website and now I'm wobbling all over the place.
I'm running spidertrax wheel spacers and steel rock crawler rims. I'm wondering if I should break the bead again and add a couple more ounces to the tires but don't know if that will fix the problem or not.
I'm running 30psi right now, I might play with some different pressures to see if that changes anything.
Any thoughts or ideas?
