spinning the tires 180 can help a lot as well.
if you go back in, ask if you can watch the tires as they balance them/spin em. then you can see in which direction the tire/wheel combo is moving. if its side to side, up and down, or just one spot that is out of whack
i run the air soft in everything i own, including my dually
you alomost can't have too much of the BBs, they will fill in the bad spot balancing the tire, any excess bbs will then distribute themselves evenly around a balanced tire,
i usually run 1/2 a large can of the .12 weighted pellets or 1/2 a smaller can of the .25 weighted pellets.
do not try and match what was on the tire in lead weight, more is better, if you use exactly what was on the tire in lead then there is no way to have a balanced tire if you were to tear off a lug or two on the trail.
personally i would not use the copper bbs
if you are having bouncing tires with the bbs them you are not running enough of them. or you have another issue that has surfaced coincidentally
I used zinc bb's in my Maxxis Mudders and had great results. However when I bought my KM2's I tried the same thing and had crappy results. I tried different amounts of bb's with no positive results. I finally got really tired of the wobble and had them balenced with stick-on weights..... no more problem!
