really quite easy.
1. Remove the outer nut on the end of the shaft before you remove the belt. Simply unplug the compressor, connect the wire from the compressor to the + of the battery to engage the clutch and use the belt tension to hold the pulley while you remove the nut. If the clutch won't engage at all then jam a screw driver in there somewhere to stop it from spinning.
2. Remove the belt.
3. Remove the 4 bolts holding the compressor down.
4. Place the compressor somewhere within hose reach that makes it easy to access the face of the pulley.
5. Remove the outer plate with the splines (pry off with a screw driver)
6. Remove the 1st snap ring.
7. Use a gear puller to remove the outer pulley.
8. Remove the small screw & clip holding the wires down.
9. Remove the 2nd snap ring.
10. Use a gear puller (if required) to remove the coil assembly.
11. Replace in opposite order of removal. Coil assembly, large snap ring, screw & clip, outer pulley, small snap ring, splined outer plate, 4 bolts, belt, nut.
12. Taa Daa, all done!
