Interior foot well light on 94 xj
dline
Can anyone post a picture of the location of the interior courtesy footwell light under the dash on the drivers side
I can't find the bulb anywhere in the wiring
They are located underneath the dash on both sides closet to the doors. As you see in the picture each light attaches to a metal bracket. If you cant find the were the bulb goes into which is a bright yellow socket then chances are the entire assembly was disconnected at some point from the wiring harness. Look at what the connection were it plugs into on the passenger side looks like then find that same connector on the drivers side, then just find one at the junk yard and plug it into yours.
