Installing Spartan Locker in c-8.25 w/ 4.56
jeepersanch
Buena Vista, Co
SO... I ran into a snag. I have the C-8.25 on my 97 XJ. I have 4.56 gears in it. I am installing the Spartan Locker in it. My problem is, My ring gear, since it is now 4.56, is really thick!!! I cannot remove/install the center pin without removing the Ring gear. With the Locker in, I cannot get the c-clips in since the center pin had to be installed before the ring gear. I NEED HELP with any ideas on how anybody got through this problem. Thank you in advance for any and all help!
:hang::tears::hang::tears::rattle:
^ What he said. You have to try to position the ring gear on the carrier so that you only have to grind one tooth but sometimes you can't avoid grinding 2 teeth. You don't have to take very much off, just enough to allow the pin to slide past.
