in need of adj trac bar
red91
ANYONE got an adj trac bar or maybe a relocation bracket for say a 4-5 inch lift? Looking to add some more height since I am experiencing lift envy...
Are you looking for one for free? I would buy the teraflex adjustable front track bar. Avoid the skyjacker one...its puny and will wear out on you way too fast. Currie makes some good ones. You will be looking to spend 140$ I had a used one you could of had but I chopped it up. Really...its probably something you want to have that is brand new as if you get a used track barthe joints may be worn and it might be bent and then you could come down with a case of death wobble. If all else fails go get some DOM tubing and make your own...piece of cake...
