Important
b857056972981e0f209df5d17d1a83aa.heic
mac ‘new RV shoes’ gyvr
Post it in the Den!
Bearings are soft. Mine spun both carrier bearings and toasted the outer pinion bearing with only 210k. Went through 4 salvage yard front diffs before rebuilding mine as mines gears where still good with no cracks or odd wear due to bearing wear.
It was 98/99-02 years, 03+ mo better. Sounds like a hub going bad when the diff bearings go. That is a good price none the less for the axles.
b78049145c85a123da45f4d2ea15076d.heic
Found something to do with the badges I purchased while at Redbird. If only they would help me make MOAB work this year...
1047192eee76c2a5f544318b003248a7.heic
f6216073dd72cd4c3f095b0430d0b455.heic
The winch line special that JR talked about at Redbird...
mac ‘Moab prep’ gyvr
So, I guess I haven't been here since Redbird trip(thanks Matt for calling to make sure I was alive). I hit a tree and bent my lower control arm brackets at Redbird. Worst part is that is was on way out, done for the day.
The Chuck Wagon has been on jack stands since I got back:
The neighbors think I am weird(course I have never met so many of em before).
While tearing it apart I found the short side axle shaft had 3 missing caps, not sure how it didn't break.
Bought some spicer joints and some clayton offroad lower control arm brackets.
Welded the LCA mounts on and will weld the caps on the new ujoints.
Now I am not a professional welder(not a very good amateur one neither). So any thoughts on how to do it better?
I am thinking I need a shake down run before I haul it down to Harlan. Anyone wanna do a day trip to Bundy or Rouch next weekend?
