Important
i suck at making bloody Marys.. ohh well on to the beer its past 12 now.
there is a brand new LY6 gm 6.0 for sale out here for $600...supposedly a gm crate motor. im not sure if i can use it, but i'm trying to put the cash together for it. if anyone else wants it, let me know. they are beastly..supposedly better than an lq4 or lq9.
Type: 6.0L V8 (LY6)
Displacement: 364 cid (5967 cc)
Engine Orientation: Longitudinal
Compression Ratio: 9.6:1
Valve Configuration: Overhead Valves
(2 valves per cylinder)
Assembly Site: Romulus, Michigan
Valve Lifters: Hydraulic Roller
Firing Order: 1 - 8 - 7 - 2 - 6 - 5 - 4 - 3
Bore x Stroke: 101.6 X 92 mm
Bore Center: 111.76 mm
Bore Area: 648.59 cm2
Fuel System: Port Fuel Injection
Fuel Type: Regular Unleaded
Horsepower:
385 hp (287 kW) @ 5600 rpm
Torque:
400 lb-ft (542 Nm) @ 4400 rpm
if he's not got the GM paperwork I wouldn't believe it.
If he bought it he knew what he paid and 600 is no where near what it's worth.
Better.
Broke three shear pins on my snowblower...
Off to the grocery in a blizzard for peace and quiet.
mac 'snowmaggedon' gyvr
I'm trying to get a little more info out of the kid now. Sounds like he is in money trouble and needs to move it. Not sure if there is a way to verify the build without paperwork or not. I may go look at it tomorrow if it doesn't snow too bad here tonight. I'm pretty skeptical right now...that's a 2500 crate motor
Sounds like he stole it out of dads garage.
thats what i'm kind of worried about actually...all the pics he have of it with the oil pan and valve covers off look brand new. even if its not a gm crate, its still worth a lot more than $600 if everything is new.
HINT: Turn the engine off when you attempt to clear the auger, even if the drive is not engaged
only have about 2" so far but it is supposed to go all day, I want a lot more!
donuts in the jeep :clap:
im lazy...i just keep an old broom handle with me that has an L shaped piece on the bottom...disengage the clutch and jam it in there. its made some crunching sounds at times, but i still have all my fingers
I'm trying to get a little more info out of the kid now. Sounds like he is in money trouble and needs to move it. Not sure if there is a way to verify the build without paperwork or not. I may go look at it tomorrow if it doesn't snow too bad here tonight. I'm pretty skeptical right now...that's a 6000+ crate motor
fixed.
seriously, go look at summits website for a late model 6.0 goodwrench reman. They're all 6+ with a 2500 core charge.
If it's just a parts yard motor cleaned up and painted then $600 is what it's worth. If it's been rebuilt then maybe $1000-$1200. If it is actually a GM crate motor with 0 miles then it's worth $3k to $4k. If this guy is actually selling a 0 mile crate motor for $600 he's an F-ing moron! Otherwise as long as it runs and has no issues it's worth the $600 he's asking. FYI this will swap into any LS GM vehicle bolt in. You'd just have to have the ECM reflashed which can be done for a few hundred from Blackbear Performance.
It sold...not sure what it actually was but someone may have gotten a steal. Either that of the guy got scared off by all the questions he was getting
I have been unimpressed by everything on this years Super Bowl, except the Doritos commercial..... So far
