BRIANHO13
<- Yum Chocolate
- Spring, TX
This is your brain when you don't buy Warn...
At least they went b4 your shafts, I always had the shafts go first with my 44......why I went to a 60.
a lot of times this depends on who's doing the work.In grounding those outlets, wouldn't that fall under the "replacing all existing wiring" regulation once you get in there? I know some places are like that...something about replacing ALL old if any?
Word. Or blue.![]()
I didn't break the hub. I was testing its durability and I placed it in the box because that's where it came from and I figured it wanted to go home.why you break it?
At least they went b4 your shafts, I always had the shafts go first with my 44......why I went to a 60.![]()
You should really talk to woody, I told him some things about this exact swap that might help, or maybe I just confused him. I'm not sure but hopefully he can actually speak from experience instead of theoretical engineer "this should work but I haven't tried it" ideas :yap:Back to this. It is the one with out the precats. Exhuast is no big deal because it currently doesnt have one anyway. I tried holding a screwdriver to my ear and then the oil pan and trans but the difference was very minimal.
Going to drop the oil pan tonight and see what i can see. May just start pulling the motor and go buy that 96 after my wedding.
Just find the first outlet in the series on every receptacle circuit and replace it with a GFCI. them piggy back the rest of them off of that receptacle. If done properly all of the outlets will be protected by GFCI, which is better than just a plain old grounded outlet.
Just do not put them in line with a freezer, an iron lung, an oxygen tent, or other important equipment, they like to false trip a lot.
sorry for another stupid tech question...my fuel pressure tests fine on prime and idle, but the symptoms i'm having point to fuel pump. loss of power while accelerating, engine trying to die occasionally like its running out of gas. only happens when im driving it, not when its sitting. pressure is 40 on prime, 47 while engine is running. i dont have a way to get the pressure gauge close enough to the cab to see while driving. i don't want to spend the money on a fuel pump unless i have to.
the question is not stupid.
you not putting what year your junk is makes it dumb.
First real obstacle at wf was the first hub.
First real obstacle at R&V was the second.
I have not wheeled between the two.
Mile Marker=suck.
Not sure that its because they weren't warn...
I think its because they were D44 hubs in general...
I think a D30 with unit bearings would've held up better...
mac 'go 60 or go home' gyvr
also wouldn't vacuum issues cause a high idle? or would there be silly issues while the vacuum system is charging on start up? all the issues i have are gone within 5 minutes of startup when running down the road
