the original motor had a spun bearing and rod knocking.
not the lowest compression cylinders. number 2 and number 4 on the drivers side. everything appears to be grounded properly from the coil packs to the motor to body grounds.
i may switch coil packs around and see if anything happens, however, its not throwing any codes for the coils being bad. the code that was thrown was us pulling the wires off the coils as it was running to see if the motor changed when it dropped a cylinder. all coils worked with the motor was pulled, i don't see two going bad while swapping a motor out.
it doesn't idle right. sounds like its blowing air back through the intake.
we think that they either installed the wrong year cam pickup wheel on the passengers side or they set the timing wrong. either way that was the point of paying him 2100 bucks to build us a reman motor so we wouldn't have to set the timing. either way the fix for both is to tear down the entire front of the motor again...
i'm going to call him with compression numbers tomorrow and see if he has any words of wisdom.
mac 'not easy fix' gyvr
