XJosh95
- Green Bay, WI
There's nothing in the DPF exhaust side of the engine that has any mechanical consequences.
Deleting the DPF portion of the exhaust is as simple as installing a regular exhaust system and uploading a computer program that eliminates the check engine light and the DPF recharging or whatever you call it.
The reason it was all smoke and mirrors a couple of years ago was because the diesel tuners hadn't had an opportunity with the new software to rewrite the DPF out of the program. So people were taking the exhaust off and living with the check engine light, but the computer was pissed when it didn't get the information it was looking for.
Now that the tuners have had a couple of years to chew on it, you just upload a custom tune and take the exhaust off.
Now, the custom tune part will get you in trouble with the dealership. . .
Makes sense. I'm a light duty tech so I don't see too much of that. I guess it's like tossing on a high flow exhaust. Plus, you wouldn't have to keep one of the ugly tips on to cool EGT at exit. And with the custom tune getting you in trouble at the dealer, with GM's ECMs, they store x-amount (I think 7) of the last program numbers. So, to avoid the scan tool from being able to know you've reprogrammed it for more power, you'd have to wipe it out with a factory code that number of times. Then it gets dangerous. Our modules will often lock up, burn out or whatever you want to call it when they've been programmed only a couple times. Kinda like a self-destruct letter Inspector Gadget would get.
