Important
Very cool Byron! It's retro........I'm envious.
<chuckle> And the saga of the neighbor's ZJ continues..... it's eaten the tcase C/V joint assembly on the front driveshaft. The cross wore through the cap, and started to chew through the C/V cage. 3 u-joints and a centering ball were almost $80, and no idea what a C/V cage went for, so a complete driveshaft is on order for 2 bills (and will be here Monday.)
West Boggs Lake in Loogootee, IN.
I'm loving the classic look of the Waggy and the boat. It gets a lot of glances at the ramp. Best part is it's not my boat, it is being stored at my house so I can use it whenever :D
it does look nice. we got a 71 glastron. the vintage stuff does get the looks
No problem Sean.
I need to replace two tires on the trailer right away. I noticed after I hit Green Bay that the two front tires on the trailer have broken belts in them.
I cannot believe it made it home like that. With a jeep on the trailer I would of been finding a tire shop in Janesville. Also forgot to ask you about the spare. Is there one?:D
No no spare, well there is one but it is shared by other trailers.
I never noticed any tire problems.
Note to self:
check your phone to make sure the battery did not die somewhere in Wisconsin, then when you charge it, check to see if you have any messages.
Duh.
Sorry Kim.
Rev
If that is the one you got from NITE... Kim better check his valve stems... All five of mine cracked and caused me to lose a tire on I-80... On a year old trailer.
I just finished up reading the Heroin Diaries by Nikki Sixx. WOW, that is all I can say....
I started it yesterday and finished it this evening, probably b/c it reads like a 4th grader put it all together. If your even the slightest fan of the Crue, it is worth the read.
Dads got a 63 S.h.a.s.t.a. (Sorry i had to do that otherwise it put Shasta) pull behind camper. 14ft. sleeps two.
Neat little camper.
We put baby moons on it. Now all I need is a 65 Chevy C10 to pull it with.
Why are my buddies checking out that mustang instead of my sweet XJ?
Guess I need one of these to be really cool...
Yeah, got them from Rewster. Just need to find some center caps, that don't say Ford.
Looks pretty sharp John!(XJ) I'd drive it.:D
Hey John, would the center caps out of a set of the XJ country/limited wheels possibly work on those Ranger wheels? If so, I have a set of the silver caps off of a 98 Country that I would send to ya for free. If a need the measurements, let me know.
Thanks Tyler, but unless those are bigger than the ones from Cindy's 99 limited, that I had on the 94 previously, they won't work.
I need something about 2.5" diameter. There's a hub cap place 5 minutes from my house that would probably have something, just haven't had the time to get up there.
