- Southwest IN
Hit a small deer last Tuesday in the Blazer. Had I been in the XJ, I doubt it would have scratched the paint.
my last eight tracks were the Beach Boys and Chicago
BOB
That's not bad at all for a d-shaft. Catt Trucking here in Vincennes quoted me $188 just to go through the CV joint on my rear ds on the XJ. That was just 2 ujoints, labor and a yoke.
I pulled the joints, checked everything (yoke looks to be fine, maybe needs greased) and plan on putting new joints in tomorrow. It appears the inner joint had some play, hopefully that's what was causing the vibration and squeal.
that doesn't seem too bad, mac.
P "that's a huge b!tch" Main
Double check the centering ball.:twak: JIM.
Mac
I'm pretty sure I remember you are running air bags? Check and see if you have the rear proportioning valve attached to the rear axle from the frame. If you do then cut the thing and lengthen it. That will give you your rear brakes back. <---your truck does not know its loaded because of the bags.
I was smokin through the best severe duty pads and rotors that I could buy. I checked out a camper forum and found the advice about the prop. valve on the rear. My truck with 130k on it showed almost no wear on the rear shoes. I know you have disc, but there is still a chance you have the valve.
Big Hankster
mac 'maintaining a fleet' gyvr
Congrats on the shop Tyler! Add a beer tap and stripper pole to the list and you'll be set![]()
I do have air bags, not sure about the proportioning valve, but I will check that out...
my fronts are toast because the previous owners allowed the front pads to wear to metal on metal smoking the rotors...instead of replacing pads and rotors they just put pads on...all of which i didn't notice until right before leaving for moab...so i have to fix what they didn't fix properly...thanks goodness for an exhaust brake...
btw, picked up the driveshaft this afternoon, 6061 aluminum...at least 5 inches in diameter, 82.25 inches long for $325...
working a part time right now, will snap a pic before i throw it in this evening...and then take a hot lap...
Got mine in too... still squeals once you get to 20 mph, and then anytime after that. On deceleration it is worse. Still sounds like a ujoint, as it squeals at yoke speed, not RPM or wheel speed. Dammit.
Not entirely sure what's making noise, I guess the centering yoke could be more worn that visible with the eye.
got the shaft in...got vibes at 70+...
forgot there was still air in the bags from moab...gonna let that out and give it another go around this weekend and see if the vibes disappear...
mac 'long, hard, and vibrates' gyvr
