Important
Made sure cubbetm got his priorities in order while he was here.
mac 'I put it on for free' gyvr
Note to self. If a friend gives you free gears assume they will make your jeep sound like a semi riding the rumble strips... because they will.
Never the less going to throw my spare front shaft in, slap a caliper on, mount my 35s and destroy this pile tomorrow at the badlands.
Don't forget you'll need it for March...
i am 95% sure the purple jeep i bought does not have a blown head gasket...really acting like timing is off (most likely plugs out of order)...no coolant in oil or vice versa. started for a bit tonight, but dies instantly. its blowing exhaust out the intake too. i'm going to do a compression test tomorrow, but there is a glimmer of hope that this thing will be an easier fix that i though
Still waiting on my member decal..
Ah ok. It was beginning of the month, January 2nd I believe
FYI. In the 100+ head gaskets I've done on 4.0s I've only ever had 2 that had oil/coolant mix with almost no tail pipe sweet smell.
Do compression test to see. I have had a few that tested bad head gasket up ended up being a bad chain.
When did you join/renew?
It takes up to 4 weeks, if it's been longer, PM Membership.
Yeah, you should see it within the next couple weeks or sooner.
You joined on January 2nd.
Your packet, along with the first 20 people that renewed in January went out Friday morning. If you didn't get it today, I would expect you'll see it Tuesday, due to no mail on Monday.
There's a Membership FAQ here: click
Thanks
M
I'll have a month to fix it!
Edit: thanks for letting us use your garage macgyvr.
No problem sir.
I hope that you got back home ok.
mac 'see you in March' gyvr
30 days til pitchers and catchers report...
34 days til the Dayton 500
mac 'not that I'm counting' gyvr
